Intake pushrods - to long!!!
Old Jan 17, 2008 | 10:49 AM
indianut's Avatar
indianut
Default RE: Intake pushrods - to long!!!
sunk valves
Old Jan 17, 2008 | 04:32 PM
Hal64hd's Avatar
Hal64hd
LOL
Old Feb 3, 2008 | 02:07 PM
MontanaPanFan's Avatar
MontanaPanFan
6th Gear
Hello to all ,
I finally took the push rods to a machine shop, had 1/8th inch turned out on a lathe, and pressed the end back in the 1/8th inch, I tried to pull one tip, (HINT - do not do this!, just turn and remove the material with the end in place, and then press down until flush.
I checked with my friend who did the valves, said the valve heights and spring dimensions were correct.
So, I turned them and shortened them, and I am moving on, not exactly sure of the problem, and yes, there are many possibilities from wrong parts in the chain of parts, but I did have the correct push rods for a 61'
Now I have a magneto issue. Please se my new post on the magneto issue.
Again, thanks to all for comments and suggestions.
MPF
Old Apr 6, 2008 | 01:44 PM
juaniosa's Avatar
juaniosa
hello bros,
i have a problem 51 pan head pushrod adjustment anyone know how to.
need help thanks bros
Old Apr 28, 2008 | 06:57 PM
doc308's Avatar
doc308
What kind of problem are you having? Are you just looking for thr right adjustment specs?
carlgrover
Ironhead
Jul 4, 2019 01:53 PM
terrapin88
EVO
May 9, 2013 10:33 PM
kiowadriver
Shovelhead
Jun 27, 2012 04:00 PM
Born2cure
May 30, 2012 12:35 AM
Reffixer
Exhaust System Topics
Jan 10, 2006 01:22 PM
