pan questions
Old Aug 1, 2009 | 11:14 PM
tadams's Avatar
tadams
Default pan questions
ive recently taken my 1950 pan to a man to fix some leaks..it has been converted to a belt drive, the original chain oiler was plugged off.. he said this cant happen the eng needs to breathe so he ran a hose out of the primary for a vent...is this normal ????...he also told me i need an oil pump becuase my oil pump is not returning all of the oil back to the tank causing some my leaking problems....does this sound normal????? just some things i would like a second opinion on
Old Aug 2, 2009 | 09:24 AM
Hal64hd's Avatar
Hal64hd
If the oiler/vent was plugged, that would cause crankcase pressure to build thus causing leaks everywhere and also affects the scavenging of the oil out of the crankcase.
Old Aug 2, 2009 | 11:34 AM
panz4ever's Avatar
panz4ever
tadams...definitely you need the vent. Just connect a hose to the vent and run it to the rear of the bike. And for your wrench's infornation, not all of the oil is/should return to the tanks. Until 65 MoCo operated on a constant loss system. 65 pans were the first with the outer aluminum to suck oil from the primary back to the oil tank. With the tin and a chain, part of the oil was used to lubricate the primary chain and fall/drip on the ground (hence the term, Harleys always mark their spot).
I say vent it first and run it to see what happens. Almost seems as if he does not know a great deal about older bikes or he does and assumes you do not and is trying to get more money by selling you an expensive fix you may not/do not need.
Old Aug 3, 2009 | 11:19 AM
tadams's Avatar
tadams
Default pan oil pump
iwas also told by another source to take the oil pump off and clean it and the lines.. ii sat for some years before i got the bike if that matters
Old Aug 3, 2009 | 11:22 AM
tadams's Avatar
tadams
do u know where a person could find a dual coil cover mine has two dynas
Old Aug 3, 2009 | 07:00 PM
sqdealgeorge's Avatar
sqdealgeorge
Good luck on finding coil covers leave them exposed or paint them As for the engine vent I run a hose off the engine vent (after I take off the 90 degree to the old chain ) I drilled a 3/4 in hole through the inner primary (about half way between the front engine pulley and the clutch basket ) I put a 1/2 in copper 90 degree inside the clear hose so no kinks occur then run the lose up the vertical frame tube under the seat I put on a 3/8 unifilter and surround it with 1 1/2 pvc pipe cut to length This pvc covering will kind of keep the oil from turning chocolate after running in the rain Are you confused ? I am but it does work My 46 knuck and my 52 pan/shovel (prim belts) use this system
73 shov
May 5, 2012 08:46 AM
chateau
Shovelhead
Jun 14, 2011 01:01 PM
panz4ever
May 9, 2011 11:46 AM
santa1
Exhaust System Topics
Sep 26, 2009 06:36 PM
pitbull1
Ironhead
Oct 17, 2008 08:48 AM
