Crush washer
Old Jun 5, 2010 | 01:19 PM
65_glide's Avatar
65_glide
Default Crush washer
Fellas,
I have a slow fuel leak at the bottom of my left tank where it connects to the brass fuel line. I was told I need replace the two crush washers under there. Any one know what size they are? JP doesn't have them, so I was thinking of picking up at a hardware store that has pretty much any nut, bolt, screw, and washer imaginable. If y'all don't know, I'll take it apart and bring one with me. I thought I would try to pick it up while I was out and about today. Have a good one and ride safe!!
John-
Old Jun 5, 2010 | 03:31 PM
0734's Avatar
0734
I haven't a clue as to what size you need, but only want to make a comment about a crush-washer. It's called a crush-washer, because as you tighten the connection (as on a brake line banjo).....the washer is soft enough to deform to any irregularities. It's usually copper, aluminum, or some combination of an alloy. If you pick-up a steel washer....I doubt it will work.
Old Jun 5, 2010 | 08:58 PM
panz4ever's Avatar
panz4ever
What you want is the copper gasket that is used for the Linkert bowl locknut #27376-28. It is copper and is an exact fit.
Old Jun 6, 2010 | 01:40 AM
65_glide's Avatar
65_glide
Thanks,
I was planning on looking for a copper washer today, but I'll just order the 27376-28 from JP. Is this the one you're talking about??
http://www.jpcycles.com/search/searc...=All&x=23&y=11
Thanks again!
John-
Old Jun 6, 2010 | 08:59 AM
panz4ever's Avatar
panz4ever
Yup, that's it. been using those on my 65 tanks for seems like forever now. Keep a few extra around because they are cheap insurance. They do not work twice (tried to reuse them, not a good idea because the 'crush' is already gone)
Skyking75
15
Dec 11, 2018 03:05 PM
fabric8or
Oct 29, 2012 07:17 AM
Kaycee
Oct 14, 2012 03:10 PM
landslide03
Exhaust System Topics
Jun 21, 2012 09:09 AM
ironhorse62
Dec 1, 2007 05:01 PM
