wishbone frame
Old Jan 29, 2007 | 12:05 AM
61bobr's Avatar
61bobr
Stage I
Default wishbone frame
I am rebuilding a 61pan and have found A PRE 57 WISHBONE FRAME AND AM WANDERING HOW BIG A TIRE I CAN GET ON THE BACK. iT MEASURES 8-5/8" AT THE AXLE PLATES
tHANKS AND E-Z-KIKIN
Old Apr 2, 2007 | 12:18 PM
Hoze's Avatar
Hoze
6th Gear
Default RE: wishbone frame
The real question is, after you fit the fat tire, how do you offset the tranny so that the drive chain clears the tire. Aye, there`s the "rub". The 8" between the axle plates is not the limiting factor.
Old Apr 5, 2007 | 05:26 PM
pittguy's Avatar
pittguy
500-16 if setting up stock using stock style fender.Tire types look wider than others.A 500-16 coker looks wider than most.
QNman
11
Apr 6, 2020 09:22 AM
phipsi74
Wheels/Tires
Aug 10, 2010 06:25 AM
creep1
Jul 5, 2009 03:24 PM
waltvtx
Custom Models
Sep 2, 2008 06:08 PM
bastardmaker
Jun 9, 2005 03:39 PM
