Performance Machine Axle Adjuster Kit
Available for 2009 and up Harley Davidson Touring models, each kit comes with a stainless steel 25mm diameter axle thats held in position by a pair of gorgeous CNC-machined aluminum axle adjusters. These adjusters allow the discerning rider to easily adjust the rear axles position for both, proper belt tension and correct alignment. Once youve got the wheel positioned properly, cinching those axles into position correctly is easy using the high-quality hardware thats fitted to each adjuster assembly.
For those of you running a machine with a 2-into-1 exhaust, you can use the included swingarm spools (which are removable), with a rear stand to lift the rear of your bike up for storage and maintenance.
We have these American made axle kits in stock, in black or gold finished - ready to ship! Get yours by calling TJ on 888.575.6570 ext. 817 or email forums@partsgiant.com and be sure to mention you saw this post on HDF and hell get you sorted out, fast!
Contact us for discounts exclusive to HDForum members. Some exclusions apply.
Email: forums@partsgiant.com
Phone: 888-575-6570 ext 817
www.partsgiant.com
