Reverse the Rear Axle
Old Dec 3, 2019 | 06:22 AM
Carl Childers's Avatar
Carl Childers
Default Reverse the Rear Axle
I change my own tires and on my old 01 Dyna It got to be a PITA to remove the muffler every time I had the back wheel off to pull the axle out so I reversed the axle which took care of that problem. I could pull the axle when needed with the muffler in place and it never effected the rear wheel. Looking at my new to me Softail I see the same situation. I haven't had the rear wheel off yet but out of curiosity Has anyone reversed the direction of the rear axle on their Softail?
Old Dec 3, 2019 | 06:54 AM
RANGER73's Avatar
RANGER73
It's been discussed before. My opinion is the reason the axle is installed rt -lft is IF the cotter pin breaks
the pressure of the hub Might unscrew the axle from the crown nut.
Granted a lot of things would have to happen for this, but **** happens.
Old Dec 3, 2019 | 07:04 AM
Mallard Slayer's Avatar
Mallard Slayer
I have the rear axle reversed on my 2005 fxsti for the same reason no issues here! except when I went to put axle nut covers on I had to make a miner modification to make them work.
Old Dec 3, 2019 | 07:26 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The axle on my `89 Softail has been reversed for over 30 years without an issue, the dealer installed it this way during the setup of the bike (I bought it new).
The factory installed the axle with the nut on the left side, I think the reasoning was that in case the bearing seized, the axle might turn, and it would be in the tightening direction...
I think it has been proven to be of no issue by the hundreds of thousands of HD`s out there with the axle nuts on the right side.
Old Dec 3, 2019 | 08:56 AM
Bluraven's Avatar
Bluraven
Reversed axle on my 09 Heritage to clear room on the left side for hard bags.
No issues.
Old Dec 3, 2019 | 12:26 PM
ghost183's Avatar
ghost183
i have mine reversed too as well as the swingarm thru bolt too.. bolt slides out on left side of bike instead of right, nuts are on muffler side
but as ranger stated the reason, i drilled a hole thru the axle and swingarm bolt (nut side) and installed a cotter pin to be safe.. my axle nut is behind a cover so i have plenty of room in there, but the swingarm bolt was tricky but doable
ronyd
Jul 20, 2010 02:05 PM
basstracker05
Feb 1, 2009 11:42 PM
GMANFATBOY
The General Motorcycle Forum
Jan 26, 2009 06:54 PM
TIPN8R
Jun 30, 2008 07:24 PM
tatkin
Jan 1, 2007 12:42 PM
