Prepping and painting engine on bike
For primer, I am concerned that the newly bare metal might need a primer to hold the paint properly and not just reflake in 3 months. Is there a tried and true spray can primer?
Then for rattle cans of paint, what works best? I know some have used BBQ paint, but I would rather hear from someone who has used a better product in a spray can, and has had the results last for some years. I think the flat black paint that is still securely attached to the jugs and case will be fine to leave on there and paint over, but again, I am concerned about peeling if disparate paints are used. Anyone have some wisdom they could share on the topic? Thanks!
Can't think of brands right now, been a while since I've done an engine; probably some better stuff available now, too. I like satin finish better than flat, seems more durable and cleans easier; I've had good results in the past.
One last thing about sand/grit blasting, you need dry, filtered air. Those cheap blasters clog up real easy without using a filter.
http://www.homedepot.com/p/Rust-Oleu...8502/100645381
It is a great match for older evo's in color and finish. The paint seems to hold up just fine to oil and fuel. Brake cleaner will remove it but you have to rub it pretty hard with the brake clean to get it to come off. Not sure if it is the paint, the heat baking, or the catalyst (below) that gives it the fuel resistance, but it's holding up fine after two season.
I also thinned it with automotive paint enamel reducer (yes, I know rust-oleum says to use acetone). I like mixing the paint on the thin side, it makes it easier to blend new to old. I also added hardener from my local tractor supply:
http://www.tractorsupply.com/tsc/pro...t?cm_vc=-10005
I cleaned up my cylinders and fins with a stainless wire brush and a bore brush to get in between the fins, washed and dried with blow gun, wiped it down with grease and wax remover, taped off as much as I could, and even used an old foam swim noodle toy cut in half length wise, and cut slits in it to push into the fins to keep overspray from getting where I don't want it. This is the biggest issue and most time consuming part of the project. Sealing up, taping, draping, etc. Enamel overspray don't want to come off paint and chrome without a fight.
I used Grandpa's old badger air brush. I really like the control you can get from an air brush and a cheapie can be had for about 20 bucks. Don't rush the job and pick areas or sections that you can "blend in and blend out". The air brush lets you get in tight areas, up close, and has lots of adjustment like pinpoint spray. I think the biggest plus is control. If you put on too much paint, you lose that "grainy look" so just put on enough to cover.
Of course practice first to get the hang of things and get the air brush dialed in.
I like the fact that I can get all the materials locally. You can experiment with the hardener to change the gloss level, just be careful, it don't take much to make things too glossy. I only ad a few drops per ounce of paint.
Let dry overnight, then give it some good heat (ride it!) YD
