Engine paint
Old Nov 4, 2012 | 08:41 AM
Jorno's Avatar
Jorno
Stage III
Default Engine paint
Hi!
I've sandblasted my engine. Old paint was pealing off. I've put on the first stroke of new paint, but it seems I've bought glossy paint. Wasn't really the plan.. I know this is a subjective question, but will it look good? Can it work? I was going for the matt finish, but I really don't want the hassle of blasting down AGAIN...
Another thing I'm not quite sure of is the temperature tolerance. It's 150°C (~300 in Fahrenheit). Will that do? Not sure I trust the guy in the paint store..
Thanks for any feedback!
Old Nov 4, 2012 | 11:26 AM
magna's Avatar
magna
You need to use proper heat resistant engine paint,if you have it should be ok, I would think if you want a Matt finish you could just paint over the gloss. Welcome to the forum.
Old Nov 4, 2012 | 12:41 PM
Midgard's Avatar
Midgard
Old Nov 4, 2012 | 12:47 PM
2006FLST's Avatar
2006FLST
What color are you going with? If you are going black (like the factory) Harley actually sells the paint they use. I bought it to touch up my evo and it works perfect and goes on great. I noticed you are in Norway so not sure how easy you can get it but if you have access to a dealer they should be able to hook you up.
Pistonman1's Avatar
Pistonman1
First choice,VHT engine paint.
I have had good results with Duplicolor also.
Paint over it with the same brand paint, should be ok.
Semi gloss is best, any oil on flat will make it shine.
Old Nov 4, 2012 | 01:08 PM
Jorno's Avatar
Jorno
Stage III
Thanks for the feedback guys. I've been reading up a bit and it would seem that painting over isn't such a good idea. The paint needs to be in the neighborhood of VHT, as Pistonman1 points out. My 150 Celcius paint will make the VHT paint bobble. It needs to come off. All of it.. Great.. FML.
Well, this time I'm not doing it myself.
Old Nov 4, 2012 | 11:22 PM
ryanek9freak's Avatar
ryanek9freak
The VHT Wrinkle paint is a good match to the factory HD powder coat, BUT, it has to be baked on in the oven or it will just peel right off.
Old Nov 5, 2012 | 02:08 AM
Jorno's Avatar
Jorno
Stage III
How hot does it need to be? I don't have an oven that large.. Can I put some lamps around it and maybe like an open air oven. Like an electric grill type thing. Will something like that do? Maybe I should leave this to the professionals.
dakotav8
EVO
16
Dec 26, 2016 05:52 PM
STN
Powdercoat & Paint
Jan 17, 2016 07:42 PM
sunpro
Exhaust System Topics
Jun 12, 2012 08:38 AM
saint_hog
Feb 9, 2010 06:05 AM
Moparbird
Sep 25, 2007 07:41 PM
