To do it right you need access to the back side. That means cutting it open, doing the metal work then welding it closed. Do that or buy a new tank...that's all.
Get the stud gun also with a little creativity after you get most of the dent out with the stud gun you can dolly more out going through the filler neck with a homemade dolly finished off with a skim coat of filler
Yeah I the real project here is getting rid of those awful flames (just got the bike) and the dent might as well go with them.
I did try the pops a dent (glue thing) and that was a waste of $20 and an hour of my time. Heat gun and canned air was a waste of an hour and $18. Can't really reach it well enough through the gas gauge hole, and I am not going to cut the tank open. I think the stud welder is about as far as I am going to take this, since I have never welded anything before
the stud welder isn't really WELDING you just heat bond the stud to bare metal ------------------you have to be careful doing that because of the heat involved.If you get to many in a small area and you aren't careful you can pull holes in heavy metal----------------in my experience if the glue doesn't work then you can also be in trouble with a stud gun.From your post I think you might be trying to get things done in a marginal fashion unless your canned air was left over co2 from your keg party
I've heard theres a really good chance of destroying the tank that way. Have you used that method yourself? I may be willing to try, although my freezer is full so that's a hassle
