Powdercoat & Paint A place to discuss everything about powder coat and paint for your Harley.
Frame paint damage
Old Nov 16, 2012 | 11:26 AM
Scaredofrain's Avatar
Scaredofrain
Originally Posted by 2black1s
Use a acidic cleaner to remove the final traces of rust before applying any primer or finish.
I grew up repairing rust in an Ohio body shop and I can tell you that removing every last trace of the rust is the most important step in the repair process.
And like someone else already mentioned, a sandblaster or the like has no place around a fully assembled motorcycle.
Thanks for that tip. It was the part I was concerned with. Any residual rust will render the project a waste of time. Can you tell me what type of acid? (ie phosphoric, nitric, citric)
Old Nov 16, 2012 | 04:47 PM
2black1s's Avatar
2black1s
An auto paint supply store should be able to set you up.
I've always used DuPont 5717 Metal Conditioner for removing minor corrosion and etching the surface for primer.
For removing more severe or deeply pitted rust I've used muriatic acid. Muriatic is very strong and you need to be cautious.
Old Nov 16, 2012 | 10:32 PM
j1mmy's Avatar
j1mmy
i dont think any dealer would touch the rust.. all it needs is a little sandpaper or a grinder with a wire wheel.. clean it off and paint with gloss black Rustoliem..
Old Nov 22, 2012 | 08:33 PM
ryanek9freak's Avatar
ryanek9freak
You and me both. Ohio rust is a bitch. My most important tool was an Acetylene torch.
ggrif
Powdercoat & Paint
Jul 22, 2011 05:58 AM
zird00
Apr 4, 2011 02:43 PM
98glider
Ironhead
Nov 7, 2010 08:30 PM
NSCoyote
May 17, 2010 07:39 AM
Egldr05
Jun 16, 2008 06:48 PM
