Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Clutch adjustment question
Old Jan 19, 2016 | 06:00 PM
Mdbell714's Avatar
Mdbell714
Default Clutch adjustment question
Hi I just had to replace my clutch hub, pressure plate, and clutch cable on a 91 Sportster. Now I have everything reassembled and am trying to adjust the clutch. I followed all the steps and seem to have it adjusted correctly. With the derby cover off I can see the clutch mechanism maxing out all the way to the left when my clutch lever is all the way pulled in. Heres my question: when in gear, as I pull the clutch in and walk the bike backwards or forwards I hit a spot where I feel resistance, like it's in gear, but I push past this spot, and now the clutch works fine. If I release the clutch and repeat the process it does the same thing again. Is this normal? Is it because I don't have and tranny fluid in it? Or does something sound wrong? I'm thinking I'm gonna just have to fill her up with tranny fluid and do a test ride.
Old Jan 20, 2016 | 08:14 AM
corliss@bakerdrivetrain.com's Avatar
Sounds normal, stock clutch baskets are never concentric, that's why there are tight and loose spots in the chain.
Old Jan 22, 2016 | 08:48 AM
grbrown's Avatar
grbrown
Thumbs up
Do just that! Take a short ride, to satisfy yourself everything seems OK, but then take a longer ride (not just round the block), which should settle your rebuilt clutch. Let us know how you get on.
Mdbell714
General Topics/Tech Tips
Jan 20, 2016 11:18 AM
dmlogs0
Apr 7, 2014 03:55 AM
bigredwing
Sep 1, 2011 11:00 AM
flyboyjacko
Sep 15, 2007 04:59 PM
wolf1477
Ironhead
Jan 16, 2007 04:23 AM
