Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Heel toe shifter free wheeling
Old Sep 26, 2017 | 12:30 AM
Herc84's Avatar
Herc84
Stage I
Default Heel toe shifter free wheeling
On a 2015 triglide classic heel toe shifter will not return after up or down shifts?
Old Sep 26, 2017 | 05:20 AM
RANGER73's Avatar
RANGER73
Try and isolate what's binding at all the pivot points.
Old Sep 26, 2017 | 06:03 AM
jamesroadking's Avatar
jamesroadking
The heal sifter splines are probably stripped, take it off and try cleaning up the splines on the shaft with a little wire brush and the ones inside the sifter with a spring hook or a little screw drivers blade, reinstall and tighten the bolt down real tight. If it is actually striped it will need replaced. It the future don't stomp it down so hard.
Old Sep 27, 2017 | 08:16 AM
grbrown's Avatar
grbrown
Wink
Hi from the UK and welcome to HDF. The return spring in the transmission may have broken, but also check the other things suggested.
Old Sep 27, 2017 | 10:40 AM
djl's Avatar
djl
Something could be binding but like grbrown, I would suspect the shifter pawl spring. Get the rear wheel off the ground, disconnect the shifter linkage from the shifter arm on the tranny. Rotate the wheel by hand and try to shift through the gears manually. If the arm does not return, the pawl spring is most likely the issue. If the arm returns, look at the lever, pivot shaft and linkage. No fun replacing the pawl spring.
Old Sep 27, 2017 | 10:51 AM
grbrown's Avatar
grbrown
Also while checking as djl suggests, if the spring is broken then you should be able to return the lever to it's normal position, by hand, then select the next gear and repeat. I actually rode my Glide like that for quite a while, resetting the lever with my foot after every change, until getting the spring replaced.
beary
Jul 21, 2014 12:50 PM
PFR-Captain
Jun 5, 2014 02:27 PM
brettnbama
Aug 6, 2009 11:50 AM
paguy
Jun 27, 2009 02:49 AM
evil_monster
Mar 4, 2009 08:53 PM
