Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Stripped shifter and shaft
Old Jan 26, 2018 | 10:04 PM
bell927's Avatar
bell927
Default Stripped shifter and shaft
The shifter and shaft stripped on my 09 Fxdci. Found the shifter arm for sale but can't find the shaft online. If anyone has insights into where to find one and any other details from someone that has done the work themselves I would appreciate it.
Thanks in advance!
Jason
Old Jan 27, 2018 | 09:37 AM
dawg's Avatar
dawg
A parts fiche will give you the pn# and you can order it online from an HD dealer
Old Jan 27, 2018 | 09:45 AM
prplglide's Avatar
prplglide
Try this:
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
Old Jan 28, 2018 | 09:16 AM
heybaylor's Avatar
heybaylor
back in the day when we allowed the shifter to run loose on the shifter shaft and wear out the splines, we would drill through both (at the correct setting and add a nut and bolt) until the "proper fix" could be had.
then checked the shift parts from time to time for being tight
e11charlie
Jul 2, 2020 06:48 AM
BezerkoBob
2014-2024 Touring Models
39
Jun 5, 2017 11:06 PM
PFR-Captain
Jun 5, 2014 02:27 PM
albngore
Jan 10, 2012 08:44 PM
JacktheBagger
Oct 2, 2008 09:21 PM
