Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Troubled 00 5 speed
Old Nov 3, 2018 | 11:58 AM
Raw power's Avatar
Raw power
Stage IV
Default Troubled 00 5 speed
Hello all, hoping someone can help me with my 2000 fxst (softtail stanard). I have the 88b and upgraded to 95 cu.in. high compression pistons and gear drive 211 cam. Ended up bumping my hp to 99 hp. Now I am blowing seals in my trans. I seen video of someone else doing the samething with their 88b and having the same problem. The race on main shaft is unable to do it's job do to main shaft flexing and destroying seals(main shaft seal on trans,seal inside mainshaft, inside primary seal). Is the stock main shaft able to handle the added hp? If so, would replacing the race be the ticket?
Old Nov 3, 2018 | 12:15 PM
Max Headflow's Avatar
Max Headflow
The needle bearings in the main drive gear have likely walked If the inner primary bearing race walks you can got to an SnS bearing race. BTW, I've got 80K on a 02 bagger that has been over 100 hp for 60K and haven't blow that seal.
voodoodrug
Jan 11, 2019 02:51 PM
squidly
EVO
14
Oct 23, 2018 07:18 PM
Jay Guild
May 3, 2018 10:45 AM
hover
15
Aug 19, 2012 07:38 AM
kansasroadking
Jul 7, 2008 07:18 PM
