Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Transmission removal
Old Jul 5, 2007 | 02:27 PM
79low's Avatar
79low
Stage II
Default Transmission removal
Hello everyone,
I am currently restoring a 1979 Low Rider , Shovelhead with a 4speed tranny. For dissasembling, all I have left is to remove the motor and transmission to have the frame recoated. Anyone have any tips on the tranny removal. I have one of the manuals but sometimes nothing beats personal experience. It looks like I need to take off the primary chain and clutch assembly but im not sure if that is totally nessessary. Any advice is appreciated.
Old Jul 13, 2007 | 12:01 PM
Night_Train01's Avatar
Night_Train01
Default RE: Transmission removal
There is no need to remove the clutch basket.....
Old Jul 14, 2007 | 03:37 PM
schoney's Avatar
schoney
If you have a primary chain on your ride you will need to take the entire primary inner cover off. It means having to take the starter off and yes the clutch.The clutch needs to come off toallow you to pull the tranny away from the inner primary cover and there should be bolts bolting your inner primary to the tranny behind the clutch basket. Once thats done the tranny should come off with a couple of bolts removed. If you have a open belt then you can take the clutch off with it.
Old Jul 17, 2007 | 05:15 PM
79low's Avatar
79low
Stage II
Thanks for the info. I got the primary of with relatively no problems. Btw, great looking bike you have!
RidemyEVO
EVO
75
Jul 3, 2012 09:43 PM
Docwayne72
Dec 31, 2010 03:50 PM
eglide90
Mar 30, 2008 05:15 PM
1996Softail
Jan 6, 2008 09:48 AM
missouri traveler
Jun 24, 2007 01:08 PM
