Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Periodic gear grind from first gear into second ?
Old Oct 11, 2019 | 11:47 AM
ral819's Avatar
ral819
Default Periodic gear grind from first gear into second ?
I've been noticing a "periodic" gear grind going into second gear. I can't quite pin it down with RPM's ... Meaning it does "seem" to occur with higher RPM's but, I have had it happen at lower to normal RPM's... Bike seems to be running fine otherwise, no other problems in other gears ... Occasionally I feel a tap on my foot from the shifter as well going into second ? Anyone have a similar occurrence ???
hardheaded
Aug 2, 2016 09:16 AM
bobx67
Mar 27, 2015 09:26 AM
crazyanimal
Mar 22, 2015 12:54 PM
fdh161
Sep 24, 2014 12:35 PM
gliderman
Oct 3, 2013 05:17 PM
