Gear Display on PV
Old Oct 1, 2013 | 06:42 PM
gliderman's Avatar
gliderman
Default Gear Display on PV
Set up the PV to display the gear indicator and noticed that the display will go back to zero each time I shift up or down before it displays the proper gear. It will also display 0 when I'm in 1st gear at a stop until the bike gets moving and the RPM's climb. Is this normal?
Old Oct 1, 2013 | 07:07 PM
07FLHT's Avatar
07FLHT
I haven't set the PV for gear position but my 6th gear light goes off when I pull in the clutch. Maybe the PV works the same.
Old Oct 1, 2013 | 07:21 PM
beasleyiv's Avatar
beasleyiv
Normal, at least it has done the same on both bikes I had my PV on.
Old Oct 1, 2013 | 07:26 PM
rmc115's Avatar
rmc115
It is a calculation by the ecm for load and rpm, it does not know the physical location of the shifter. Mike
Old Oct 1, 2013 | 07:32 PM
smokingpig's Avatar
smokingpig
I think it determines the displayed gear by matching speed with engine rpm... when you shift, or come to a stop the signals don't match, so it displays '0'... there is no sensor in the transmission that sends a signal up the canbus to indicate selected gear.
Old Oct 2, 2013 | 06:46 PM
hover's Avatar
hover
Mine displays zero when clutch is pulled in...such as when shifting or at stop.
Old Oct 2, 2013 | 06:57 PM
Rdgray's Avatar
Rdgray
Mine works the same as op's
Old Oct 2, 2013 | 07:10 PM
BigTwins's Avatar
BigTwins
Clutch in...0
Old Oct 2, 2013 | 07:37 PM
Sam2010's Avatar
Sam2010
Yes that is normal that's how my power vision works to.
FYI my 2014 Street Glide that displays the gear in odometer works the Same way.
Old Oct 2, 2013 | 07:42 PM
murph's Avatar
murph
Same for mine.. So must be normal.
