Gear Display on PV
Old Oct 2, 2013 | 11:27 PM
Sire2Twins's Avatar
Sire2Twins
Originally Posted by hover
Mine displays zero when clutch is pulled in...such as when shifting or at stop.
Old Oct 3, 2013 | 01:28 PM
midgetracer56's Avatar
midgetracer56
Originally Posted by murph
Same for mine.. So must be normal.
same here.
Old Oct 3, 2013 | 03:30 PM
TwistedRider's Avatar
TwistedRider
Change the lower limit to '1', then set the color of the lower limit to the display background color. Then you won't see the '0' just a blank field. A lot less irritating then the '0' popping up all the time.
Old Oct 3, 2013 | 05:17 PM
disco's Avatar
disco
BTW if you use the PV to change speedo calibration you will lose your 6th gear indicator if you go too far for the ecm to deal with.
crazyanimal
Mar 22, 2015 12:54 PM
beaucipher
Sep 2, 2014 07:15 AM
JOHNNYFLHR
Mar 11, 2014 03:28 AM
roundy
Aug 13, 2012 06:22 AM
DAYTONCHOPPERS
Jul 19, 2011 08:32 AM
