Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Bolt Problem
Old Dec 3, 2020 | 03:49 PM
Tholian's Avatar
Tholian
6th Gear
Default Bolt Problem
I'm working on a 88 Elctra glide. I had to replace the starter solenoid. the bolt that holds the solenoid towards the front into the back of the Primary casing is stripped. This bolt does not go through the casing, just into the case itself. I have a tap and die set and thought maybe tap it to the next size higher. But this is Pot aluminum. Can you tap this stuff like steel? or will I cause more problems?
Old Dec 3, 2020 | 03:56 PM
98hotrodfatboy's Avatar
98hotrodfatboy
I would go with a "time sert" or a helicoil...
Old Dec 4, 2020 | 11:13 AM
Zanthamos's Avatar
Zanthamos
Helicoil if you can time-sert if the hole is too big for the helicoil.
Old Dec 4, 2020 | 11:28 AM
86glider's Avatar
86glider
I stripped mine about 15 yrs ago. I tapped the next size up very carefully.
PaulBartell
Engine Mechanical Topics
Nov 29, 2018 07:48 PM
hAkron
General Topics/Tech Tips
May 30, 2016 06:55 PM
IceMedic75
May 30, 2014 01:25 PM
jdreed520
Feb 20, 2009 07:08 PM
Evilution
Apr 15, 2008 06:39 PM
