Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Previous owner stripped out 4 of the bolt holes for the primary inspection cover and poorly re-threaded them. So, I'm going to replace the cover. Any reason to go with something other than a factory Harley replacement?
2012 Blackline
Would definitely stick with HD as many aftermarket chrome and or coatings do not hold up.
Have you thought about turning cover and aligning between existing threaded holes and making new threaded holes?
Can't hurt at this point. Then run a flat gasket instead of the o-ring type.
Can't remember if primary is beefed up at threaded holes or same thickness all the way around.
Just a thought.
Good Luck and ride safe✌🏼
