Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Broken Return Spring?
Old Jan 8, 2024 | 06:29 PM
Kamaro1's Avatar
Kamaro1
Stage I
Unhappy Broken Return Spring?
All,
just returned from a cold weather ride on my 2003 Dyna Lowrider. Just a half mile from home, my shift foot pedal became stuck in first gear and my EZ clutch hand clutch became floppy, inoperable, and wouldn’t spring back into place. I could force the foot pedal to get it into neutral, but it’s obvious something is busted. Assume from general research that its a broken return spring, but who knows when dealing with the tranny.
Question is, is this simple enough that can I tackle this myself when it warms up? Or should I just bite the bullet and have my local Harley dealership do it. Regarding the latter, any idea how much $$$ they’ll charge to do a return spring? Thanks, any advice is greatly appreciated.
Old Jan 8, 2024 | 07:34 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Forget the transmission.
The loose clutch lever is telling you there is an issue in the clutch control mechanism, somewhere between the clutch lever and the clutch itself.
Remove the clutch release mechanism cover, inspect the ball and ramp, the throwout bearing, cable etc.
Remove the derby cover, make sure the clutch adjustment stud and jamnut, adjuster plate, and retaining ring are intact.
Old Jan 9, 2024 | 09:48 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Like Dan said.. I'm thinking cable... Shifter feels stuck because the clutch won't release..
oo10inz
2014-2024 Touring Models
Aug 24, 2023 10:26 AM
Bigdoginottawa
May 31, 2023 09:30 PM
too many scooters
May 6, 2018 05:53 PM
garyfurness
Shovelhead
Aug 26, 2014 07:42 PM
rebel3885
Feb 9, 2013 01:34 PM
