Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
07 Dyna rear sprocket
Old Apr 10, 2008 | 09:43 AM
jsbridgew's Avatar
jsbridgew
Default 07 Dyna rear sprocket
Does anyone know if my 2007 FXDB 66 tooth, 1 inch belt pulley/sprocket can be swapped outfor a 2005 Dyna sprocket/pulley that has a 70 tooth,1 1/8 on it?
Those 2005 Dyna sprockets have the 8 hole design which would match the new rotors I bought.
I know it will alter the gearing, and I'm fine with that. I'm concerned about fitment and if there are any real mods or anything I would need to consider
Thanks,
Paul
Old Apr 10, 2008 | 10:55 AM
Evilution's Avatar
Evilution
Default RE: 07 Dyna rear sprocket
I don't think it will fit without a longer belt. Even then the belt you would have touse would be too narrow for your new pulley. You might try to fit one from a Sportster, as I believe it would be the correct width, and possibly the correct number of teeth for your current belt.
Old Apr 10, 2008 | 11:10 AM
jsbridgew's Avatar
jsbridgew
Well, a longer belt isn't a problem. I wouldn't have a problem with that, I don't think.
2007 streetbob, by the way
Old Jun 20, 2012 | 04:06 PM
07bobber's Avatar
07bobber
I know this thread is old but im bumping it to the top.
Has anyone retrofitted an older pulley to a newer dyna
zimm
EVO
20
Feb 1, 2018 02:00 PM
moti
Aug 15, 2016 11:47 AM
hernan
Jun 8, 2009 06:17 PM
fixxr
Mar 25, 2009 09:50 PM
jsbridgew
Apr 10, 2008 09:47 AM
