Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Clutch cable housing.
Old May 20, 2008 | 03:59 PM
Litten Racing's Avatar
Litten Racing
Default Clutch cable housing.
I need to take off the right side trans housing to replace a exhaust bracket. If I unbolt this will any thing come out? that is other than trans fluid. It's the one that the clutch cable goes into.
Old May 20, 2008 | 04:07 PM
Rusty70's Avatar
Rusty70
Default RE: Clutch cable housing.
No, only fluid
Old May 20, 2008 | 05:44 PM
peppi's Avatar
peppi
You can cut a 1/4" allen key down on the short end just long enough to seat in the bolt and you don't need to remove the exhaust. Break the bolts loose and unscrew them by hand then lift the cover over the pipe. Reverse to reinstall. If you leave the bike on the side stand, you'll get hardly any oil out of there too.
Old May 20, 2008 | 08:01 PM
Litten Racing
Thanks for the reply. Im not taking the pipe off. Just the bracket. It'll be a good time to change the fluid anyhow. Thanks again. [sm=goodidea.gif]
Rickey
Feb 9, 2014 12:55 AM
bubdifab
Jun 28, 2012 10:20 PM
SC-Longhair
Sep 23, 2009 12:37 AM
harpoon
Mar 22, 2008 04:36 PM
RCNewton
Jul 1, 2005 02:52 AM
