Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Dyna Glide down shifting problem
Old Jun 2, 2008 | 06:02 PM
dynaride's Avatar
dynaride
Stage II
Default Dyna Glide down shifting problem
I down shifted from 5th to 4th when pulling off ofthe highway (about 60mph) on my96 dyna conv.and the bike felt like it shifted into into netrual ?Ipushed the shifter down agian and it grinded a little bit and went into gear.When I shifted the first time Idon't think I shifted hardenough to go all the way into4th, is that possible? Does this happen a lot? The bike has 18000 miles on it so I dont felllike the trany should be that worn out. Do you think this caused any reallybad trany wear? Thanks for any replies.
Old Jun 3, 2008 | 11:51 AM
lecomte38's Avatar
lecomte38
Default RE: Dyna Glide down shifting problem
No problem mon. As long as it isn't a regular happening. You can ususlly find a few neutrals in between gears if you jiggle the shifter a little. Stomp that sucker, its a Harley!!!
Old Jun 3, 2008 | 06:17 PM
dynaride's Avatar
dynaride
Stage II
Thanks for the response. I rode it some today and no problem. Just must not of hit the shifter hard enough, this is my first Harley, I guess I am just use to shifting my dirt bike.
Sammi
Aug 19, 2015 04:32 PM
blueangel73
Sep 27, 2010 01:14 PM
retiredin04
Aug 2, 2010 08:58 PM
sdal57
May 17, 2010 04:40 AM
Headwolf
Sep 2, 2005 02:38 PM
