Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
How much play
Old Jul 14, 2008 | 11:08 AM
Zzyzx's Avatar
Zzyzx
1st Gear
Default How much play
&nbsp\\;&nbsp\\;&nbsp\\; How much play should there be on the starter shaft?&nbsp\\; I have an 86 FXR that doesn't want to start, the Relay clicks and the solenoid clicks... it just doesn't engage the starter. &nbsp\\; Which, according to the service manual says its either a bad solenoid or something is binding up on the shaft side.
I checked the solenoid and it at least appears to be working, and the starter shaft has a whole lot of play in it... and sometimes I cant slide it in and out (it binds up).
Probable cause?&nbsp\\; bad bearings?&nbsp\\; any thing?
thanks, Spencer
Old Jul 18, 2008 | 09:00 PM
1flhtk4me's Avatar
1flhtk4me
Default RE: How much play
You may want to disassemble and check the parts for wear.
Just a guess,I would think bearing/bushing clearances would be less than .004".
Insureguy
EVO
11
Sep 16, 2011 03:47 PM
esf
May 30, 2011 09:51 PM
dirty78ironhead
Ironhead
Jun 15, 2008 11:49 PM
02glide
Nov 18, 2006 06:05 PM
muzzey
Dec 1, 2004 09:59 PM
