Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
oil leak
Old Oct 9, 2008 | 07:33 PM
FLSTF's Avatar
FLSTF
Default oil leak
Anyone have oil leak out where the clutch cable goes into the side cover? Just noticed a slight leak today, but the cable doesn't tighten if I turn it. It just turns around like it's not threaded in good. Is there a trick to this or should I just take it in? It's still under warranty.
Old Oct 9, 2008 | 09:20 PM
bobcowan's Avatar
bobcowan
Don't mess with it, just take it in and let the them worry about it. One of the beauties of a new machine.
Old Oct 9, 2008 | 09:32 PM
FLSTF's Avatar
FLSTF
Thanks for the reply, I'll probably just take it in. I was hoping it might be something common and easy to fix, but I guess thats what warranties are for.
Old Oct 17, 2008 | 08:58 AM
gunnert's Avatar
gunnert
There's a rubber o ring that may be leaking. Simple fix, if you can get to it without dropping the exhaust.
brad75raiders
EVO
May 25, 2018 11:53 AM
squaredaway
Jun 16, 2013 11:11 PM
twistedcherokee
Oct 31, 2010 05:49 PM
plumbertom
Feb 13, 2010 10:53 AM
bescaes
Oct 28, 2008 09:27 AM
