Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
problems putting bike in neutral!!!
Old Apr 16, 2006 | 03:53 AM
jpnelson1978's Avatar
jpnelson1978
Default problems putting bike in neutral!!!
i just bought a 2006 road king and im having problems putting bike in neutral when the bike is running and im completely stopped. i can put it in neutral easy if im moving a little, but not when completely stopped. bike has only 200 miles on it. does the shifter need to break in? is this common on new bikes
Old Apr 16, 2006 | 04:13 AM
Crazy Canuck's Avatar
Crazy Canuck
Default RE: problems putting bike in neutral!!!
Hey JP
Give it a bit of time. Mine was the same as well and was
told what I'm telling you and sure enough I have 2500 km
now and I can hit neutral anytime no problem.
Crazy Canuck[sm=smokin.gif]
Old Apr 17, 2006 | 07:07 PM
warthog's Avatar
warthog
i have the same issue on a 06 FXSTB with only a few hundred miles on it.
Old Apr 17, 2006 | 07:13 PM
chopperchuck's Avatar
chopperchuck
change the oil and put synergin in it. youll be able to hit nuetral immediately.85-140.
Old Aug 28, 2008 | 01:26 AM
Rabbit_'s Avatar
Rabbit_
Adjust your clutch, worked for me.
Old Aug 28, 2008 | 02:42 AM
hdslam's Avatar
hdslam
It is how the clutch is adjusted, don't worry. The way it is set, it will not slip. If you want to put it in Nuetral while at a stop light, not recommended, just give a slight twist of the throttle to increase rpm and shift into nuetral w/ ease.
Try that, it will work, no need to adjust the clutch.
hanny
2014-2024 Touring Models
93
Jun 28, 2015 09:44 AM
wolverine66
Apr 26, 2008 12:26 AM
beaucoup_dinkydow
Apr 14, 2008 09:50 AM
Lone Watie
Apr 10, 2008 08:04 PM
jpnelson1978
Apr 23, 2006 05:53 AM
