Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Clutch noise
Old May 27, 2009 | 09:33 PM
popsicle's Avatar
popsicle
3rd Gear
Default Clutch noise
Have an 09 roadking, 4000 mi. for about 1500 miles have a clicking sound when I pull the clutch lever in and then again when I let it out. Loud enough to hear it on the left side of the motor. Took it to the dealer 1500 mi. ago mechanic said "it was a Harley, get louder pipes." A friend that works on HD's said it sounded like the " automatic tensioner in the Primary"?? Question is do I take it to a different dealer and ask them to check the tensioner or do I take it to the original dealer and ask them? Anyone had an 09 with this problem? It is beginning to get louder and clicking when I let of the gas and then give it gas again..
Old Jun 1, 2009 | 05:15 PM
fxrkid's Avatar
fxrkid
4th Gear
Try to re-adjust clutch. I have found that sometimes when clutch is adjusted incorrectly the lever will make an audible click where release mechanism and throw out bearing meet. do a full clutch adjustment not just at the cable. If this does not remedy the situation you may need to look at clutch actuation components more closely.
Old Jun 1, 2009 | 05:18 PM
fxrkid's Avatar
fxrkid
4th Gear
Clicking when giving it gas and letting off is not clutch or primary chain. check to be sure trans drive sprocket is not comming loose. also could be the main drive gear. lets hope not. that gets spendy.
evotrike
EVO
11
May 13, 2019 08:47 PM
RedLewy
Sep 1, 2018 11:36 PM
mchertel
2014-2024 Touring Models
17
Sep 13, 2016 09:42 AM
dyna2010
Sep 6, 2015 09:35 AM
Z
Sep 6, 2008 12:15 PM
