Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
30t front sprocket how to?
Old May 29, 2009 | 02:07 PM
emwolb's Avatar
emwolb
Default 30t front sprocket how to?
just curious, anyone in here done it? i assume that the 30tooth sprocket will screw with the speedo being right, there is an alternative, changing out the compensator sprocket and clutch basket, am i right? just wanna drop the gearing on my 08 streetglide a bit.
Old May 30, 2009 | 07:06 AM
dawg's Avatar
dawg
If you go with the EVO 30T that replaces the compensator, it won't throw the speedo off. The only thing you lose is the 6th gear light. I have it and love it. Another alternative is to change out the tranny side to something like the Andrews 30 tooth kit. This will throw the speedo off about 4mph and it is more work, but you keep the compensator.
Old Jun 1, 2009 | 07:27 PM
Dalton's Avatar
Dalton
One other alternative is to replace the clutch basket with say, a 49 tooth ring gear that will give you the gearing of about a 32 totth primary sprocket. It will not screw up the speedo but 6th gear light will not work.
Old Jul 2, 2009 | 08:41 AM
bdn56's Avatar
bdn56
EVO sells the kit which includes the 30T sprocket and 84L chain. Nothing else was changed on the clutch. I did also install the SE clutch spring.
I do have a little more chain noise.
One of my best mods to date
Old Jul 22, 2009 | 01:38 AM
emwolb's Avatar
emwolb
great input guys, thanks. something to ponder now for my winter project along with the 103" provided the new 2010 models don't offer something that i absolutely gotta have.
Tim Wayne C
Mar 16, 2015 11:10 PM
bigfish_Oh
Mar 31, 2014 04:51 PM
softail99custom
EVO
16
Nov 7, 2013 11:58 AM
FLSTF
Dec 4, 2010 11:30 AM
rob71458
Sep 13, 2007 08:38 AM
