49t clutch ring gear
Old Mar 31, 2014 | 11:50 AM
bigfish_Oh's Avatar
bigfish_Oh
Default 49t clutch ring gear
I do not see as much on this as the 30t pulley swap, Will it give similar results? seems to be many hours/tools easier.
thanks for opinions
2012 RK
Old Mar 31, 2014 | 01:49 PM
nvsteve's Avatar
nvsteve
If I remember correctly it would be similar. Plus your speedometer will be ok.
Might lose 6th gear light but not sure.
Old Mar 31, 2014 | 02:08 PM
07RoadHawg's Avatar
07RoadHawg
Yes it is. All you need is a press to work on the clutch hub/bearing or get your dealer to do it for you for a few bucks. My dealer recommends (and I agree) a new clutch hub bearing while it's apart. You will have to drill out the rivets that hold the factory sprocket on and countersink the hub just a little for the new bolts that hold the 49T sprocket on.
I did this swap almost immediately on my '07 Road King and love it. No change to the speedo and the 6th gear light will work if you use a TTS (or equivalent) to update the primary gear ratio to 1.44
Old Mar 31, 2014 | 04:16 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
lowering the gearing(especially on 07-08) is one of the best performance mods for the money,doesn't seem to interest to many maybe because it doesn't come with the big inch bragging rights?
Old Mar 31, 2014 | 04:29 PM
voodoodrug's Avatar
voodoodrug
changed the rear sprocket thinking that was the easiest??
Old Mar 31, 2014 | 04:51 PM
bigdumbnoitall00
i don't know of a larger rear sprocket for a 12,07-08 thats the way to go.
Ted Jones
Nov 3, 2017 06:47 AM
Johnnyd74
General Topics/Tech Tips
Aug 1, 2014 10:19 PM
TTCHL
Apr 3, 2013 05:06 PM
dgretz
Aug 24, 2010 09:55 AM
wizardry68
Ironhead
Mar 31, 2008 07:18 AM
