Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
clutch, primary chain, compensating sprocket
Old Jun 6, 2006 | 12:41 AM
gsparesa's Avatar
gsparesa
Default clutch, primary chain, compensating sprocket
I was reading the HD Service Manual and trying to educate myself when I ran upon this lovely tidbit. “Remove clutch, primary chain, compensating sprocket and shaft extension as a single assembly.”
What is the theory behind having to remove the “clutch, primary chain, compensating sprocket and shaft extension as a single assembly.” This is documented in Chapter 6.5 (Primary Chain case), page 6-19 and page 6-24 of the2005 HD Touring Models Service Manual.
Is the wear on this assembly that critical to the compensating sprocket assembly (torque absorber)?
Old Jun 6, 2006 | 01:03 PM
jt1965's Avatar
jt1965
Default RE: clutch, primary chain, compensating sprocket
I think the reasoning behind this is that you end up knowing the chain is in the same direction as it was before. The chain will wear faster if you reverse its direction.
Also I found it to be easier to pull out and put back in.
Just my $.02.
JT
Old Jun 6, 2006 | 03:19 PM
fxstcguy98's Avatar
fxstcguy98
it's merely a matter of the primary chain doesn't have enough slack in it to be removed from one pulley or the other, thus you have to pull them both at the same time.
Old Jun 6, 2006 | 03:21 PM
Scout's Avatar
Scout
ORIGINAL: fxstcguy98
That's exactly it.
Old Jun 6, 2006 | 04:22 PM
jt1965's Avatar
jt1965
That was my other thought. I could not get enough slack to get the chain off anyways.
sandlug
13
Feb 25, 2017 04:38 PM
61flh
EVO
Jan 7, 2014 08:55 PM
dburch01
Jul 9, 2011 10:12 AM
patharley
Feb 19, 2011 11:51 AM
gsparesa
Jun 8, 2006 10:29 AM
Slideshow: Harley-Davidson's new RMCR concept revives the caf racer formula with modern hardware-and it may be exactly the reset the company needs.
