Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Oil Pump and Sumping
Old Apr 9, 2010 | 10:52 AM
asm481's Avatar
asm481
Default Oil Pump and Sumping
I guess I am just a bit paranoid but now that I have done my cam chain tensioner replacement I am concerned whether I got the oil pump centered right. It seems to run ok just reading all the horror stories has me freaked out a bit. I haven't put but a couple miles on it so when would I know if I am sumping? Does this take a while to build up or is it instantaneous. What do I look for first as far as symptoms.
Old Apr 11, 2010 | 06:55 PM
dawg's Avatar
dawg
A common symptom is a loss of horsepower. When the oil pump doesn't pull enough oil out of the bottom end the fly-wheel has to spin in the excess oil. It slows things down and makes it sluggish. If you pull the case plug underneath and you have more than 6oz of oil, it's sumping. 6oz is on the higher side, but generally still considered acceptable. You're probably fine, just paranoid.
Old Apr 11, 2010 | 07:29 PM
asm481's Avatar
asm481
I have put a couple hundred miles on it and all seems fine so far. Gonna bet it is good to go. Been all different speeds and short and long hauls with good pull all the way.
thumbbuster
Oil Archive (no new posts)
Jan 1, 2019 05:51 PM
Charles Fields
Apr 20, 2018 08:44 PM
rockstar
Aug 8, 2013 09:42 PM
Robtarra39
Jul 2, 2013 10:56 AM
MikesDad
Aug 21, 2007 08:20 AM
