Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Bearing Squeel
Old May 1, 2010 | 03:49 PM
harleydoc1958's Avatar
harleydoc1958
Stage IV
Default Bearing Squeel
I have a 02 classic. 30k. About a month ago I started hearing a slight bearing squeel sound. I got on it yesterday and now its a constant squeel. When its rolling and I pull in the clutch, it goes away. Soon as I let the clutch out it starts again. All fluid levels are right on. Ideas????
Old May 1, 2010 | 04:00 PM
Kaycee's Avatar
Kaycee
I would go and readjust clutch and see if it changes tone,allso check the drive belt.
Old May 1, 2010 | 05:32 PM
BLKBAGGER's Avatar
BLKBAGGER
Mainshaft bearing?
Old May 2, 2010 | 10:25 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Do you hear it when stopped, in neutral?
If so, does the squeal go away when you put it in gear?
Old May 2, 2010 | 11:58 AM
harleydoc1958
Stage IV
It makes no noise standing still at idle or reving. Only when moving with the clutch out. When I pull the clutch in at any speed, it quits.
sB43
EVO
16
Nov 12, 2018 03:33 AM
natural gasser
EVO
Jul 19, 2017 11:33 PM
Falcon195
Aug 15, 2013 11:08 PM
mike@americanfiber.net
Aug 10, 2012 07:33 AM
bulldawg10
Nov 6, 2010 03:53 AM
