Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
primary chatter sometimes not all the time
Old May 26, 2010 | 11:45 AM
black dyna's Avatar
black dyna
Default primary chatter sometimes not all the time
it will do it mostly after i turn left in first gear then go down the road and just before i shift into 2nd gear i get this chatter.
my bike is a 07 dyna superglide 35,000 miles.i just had a new front motor mount put on at dealer and they ajusted the belt.but it as been doing it before i took it in to dealer they say it didnt do it for them and it dont do it for me all the time.
i am thinking auto chain ajuster or stator ?
Old May 26, 2010 | 01:31 PM
dawg's Avatar
dawg
Wouldn't be the stator. It would be either the tensioner or compensator. The loose comp nut issue hasn't really been a problem on the TC96's. Many have replaced the compensator with the new SE compensator and have had good luck with clearing up some clunks and noises on startup and whatnot.
Old May 26, 2010 | 07:16 PM
soft 02's Avatar
soft 02
I'm in the compensator replacement club and it sounds like you might be a canidet! All fun aside change your primary fluid and if it looks like a metalick milkshake then it might be time to replace it with the SE compensator before it destrois the stator. HD tried to tell me to change the stator when I did the compensator but it was fine.
bbest71
Jun 4, 2018 09:50 AM
Hog happy
Aug 11, 2015 01:48 PM
SteveUltra
Oct 10, 2013 03:17 PM
hogcruzer
Sep 6, 2013 07:46 PM
toastman
Nov 18, 2011 09:41 AM
