Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Primary cover bolt stripped - help
Old Jul 15, 2010 | 02:08 PM
bmwr69s's Avatar
bmwr69s
Stage II
Default Primary cover bolt stripped - help
Have a 2009 Road King and stripped one of the torx bolts to the primary cover.
1. How can I remove the stripped bolt?
2. Where can I buy hex head or allen bolts? I'm in Germany so need to order via internet.
3. What size are the bolts - are they coarse or fine thread - what #?
thanks for any advice
Old Jul 15, 2010 | 03:30 PM
tbone52's Avatar
tbone52
Use one size larger torx bit and this
http://www.jpcycles.com/product/150-...utm_medium=cse
to remove the stripped screw. I am assuming you are saying that the head is wallowed out and the threads are not stripped.
If there is a Harley Dealer near you they can sell you stainless steel allen screws to replace the torx screws on derby cover.
The outer primary cover is already allen screws.
apetterez
Apr 21, 2021 08:26 PM
bigpappa160
Jul 31, 2018 04:28 AM
dohadex
Mar 26, 2013 07:08 AM
badfl97
May 4, 2012 08:57 AM
meatball
May 25, 2007 12:38 AM
