Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Drivetrain project help needed
Old Jan 31, 2012 | 06:58 PM
hlo5150's Avatar
hlo5150
Stage III
Default Drivetrain project help needed
Could really use some help. I have a 1988 FLHTC that I am working on for a project. I took the whole bike apart and tossed just about everything. After getting frame back from powder coating I put a 1996 96ci evo motor in then bought a fully polished Revtech 5 speed tranny part #58306 which stated would fit from 83 to 98 FLH & FLT. The tranny fits but my problem is I had a tappered shaft on original tranny and this new tranny has the straight spline shaft used on either 89 or 90 up. I do not want to swap out the pinion shaft only because parts are very hard to come by for 85 to 88 like the inner primary,starter and so on. Can I use an inner primary from 90 to 98 along with a starter, clutch pack to complete my project as parts are alot more easy to come by?
Old Feb 1, 2012 | 04:40 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
If you use a `90-`93 clutch assembly, you can still use your old primary and starter setup.
Old Feb 1, 2012 | 07:48 PM
hlo5150's Avatar
hlo5150
Stage III
Thank you for your help.
rivercityslim
Jul 26, 2019 08:48 AM
gauthier6916
Sep 19, 2016 09:13 AM
streetg131
Jul 24, 2011 09:05 AM
harleyrider-keu
Jun 24, 2011 09:10 AM
hdpeanut1
EVO
Mar 22, 2011 11:51 PM
