Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Diaphragm Spring and Spring Plate
Old Feb 25, 2012 | 02:01 PM
Bankrupt's Avatar
Bankrupt
Default Diaphragm Spring and Spring Plate
Hello,
I bought a clutch kit for my '93 Electra Glide. It came with a Diaphragm Spring that purports to be 20% stronger. I'm thinking I don't need a stronger spring....
Also, It came with extra plates (friction and steel) to omit the riveted Spring Plate that is sandwiched in the very middle of the clutch pack. I'm thinking I should leave the OEM spring plate in there.
The reason for clutch replacement is because of plate damage I did when I rebuilt it last winter causing clutch drag. I don't have wear or slippage issues. The bike is not a racer and it is not pulling very much weight but I made it about as hot as you can without boring the case for major displacement increase.
Am ready to soak plates and assemble.
So, how's my thinking? I ask because it's usually pretty dangerous.
Old Feb 25, 2012 | 07:52 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Use the extra plates and leave the riveted spring plate out, they can fail and drive you nuts trying to figure out what is wrong with the clutch.
Old Feb 26, 2012 | 11:52 AM
Bankrupt's Avatar
Bankrupt
What purpose does the spring plate fill? I see it has a very miniscule amount of compression.
Old Mar 3, 2012 | 03:34 PM
Bankrupt's Avatar
Bankrupt
Thanks for the response Dan. - But before I omit a part that Harley obviously spent some effort designing, I want to know why it's in there.
I called Bennett Clutch and they told me the Spring Plate dampens chatter.
I think I'll tolerate a little chatter. I'm hard of hearing anyways....
Scuba10jdl
Feb 15, 2024 05:41 PM
simple softail
EVO
Jul 25, 2018 02:42 PM
ariale72
Nov 19, 2013 10:31 AM
SANTA DEUCE
Jan 2, 2013 06:20 PM
bassturd
Aug 13, 2010 08:35 PM
