Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
rear wheel tight spot when rotated
Old Aug 4, 2014 | 06:20 PM
Candubrain's Avatar
Candubrain
Default rear wheel tight spot when rotated
Ive read the many posts about checking and adjusting the Drive Belt Deflection.
I don't have the tools or a garage, so this will be mechanics work, but this is my question
I had my 2014 Limited's rear wheel off the ground for cleaning, while rotating the wheel it would come to a spot where it was harder to rotate than the other areas. The bike has ~3,000 miles on it and it was serviced by the dealer at the 1,000 mile mark.
Is this normal? Is there a simple way for me to check belt deflection without tools? The dealer is an hours drive, and they will probably keep it overnight, which is a PITA.
thanks
brian
Old Aug 4, 2014 | 07:28 PM
Mikula's Avatar
Mikula
the tool is $10 on amazon, can be checked in your driveway. is the rotor warped?
Old Aug 4, 2014 | 07:37 PM
103 sedona orange's Avatar
103 sedona orange
Hard to diagnose from here. Mine does the same thing & no issues.
Old Aug 4, 2014 | 08:34 PM
Candubrain's Avatar
Candubrain
good to know
thanks
Eis
Aug 1, 2018 02:22 PM
Ozark Joe
EVO
19
May 22, 2017 10:13 AM
terrysillik
Sep 9, 2016 09:23 PM
hAkron
May 30, 2016 12:22 PM
lkr0
Wheels/Tires
Nov 3, 2009 10:04 AM
