First multi-state trip
This will be my first long distance trip on a motorcycle and it's been a while since I've been on a motorcycle other than taking the MSF 15 hour course recently.
I've got pants, jackets, boots, and gloves to cover the various weather I might run into and a good full face helmet. I'll be staying in motels at night and have a cover to lock on the scoot. I've got a GPS for traveling, a tire repair kit, and a small air pump.
Other than a credit card and some cash is there anything else I should be taking or prepare for at the outset? (Maybe recommendations on a few tools and sizes.) I've been reading this forum for the last several months and appreciate the experience and wisdom of the talent bank.
I think I read somewhere that Harley air circulator seat pad was made by
airhawk. I see the Harley item is cheaper than the AirHawk. good recomendation.
During those miles, figure out what makes you want to get off the bike and get it addressed. Simple things like highway pegs, backrest, or a different height windshield can make a huge difference on the road.
Does the helmet fit well enough to wear for many hours on end? One normally won't determine that until they've worn on it for an extended period of time.
Do you have a small hand air pump for the shocks? I wouldn't use a powered one on the shocks as it may blow the seals.
Finally, some of the little things like a small flashlight, first aid kit, hand towel, maps, pen & paper, spare light bulbs & fuses, and windshield cleaner to name a few.
Hope that helps.
Good luck and ride safe!
Now I would slap a backrest on it but I'm an old retired geezer, so I need it. That's an age thing. But I would skip the seat pad. Break in the seat, yours or the bike, depending. If your butt gets sore, stop, walk around for awhile, get gas, take a **** and drink something. Then hop on and ride another hundred miles. Repeat.
When you get down Arizona way have some water bottles. Some for drinking, others for soaking your tee shirt. The wet tee shirt trick only works while under a light or vented jacket. When you stop for gas soak the thing in the bathroom sink. Having survived the Mojave Desert I can tell you this works. While the temperature might seem perfect don't ride across the high desert in a tee shirt. At elevation the sun will cook you alive. Heavy SPF sunscreen.
Wow, that brought back memories. Traveling accross Kansas in 100 degree heat one summer on the way to Colorado I would stop at rest stops and lay my tee shirt down in the sink and fill the sink with water. Then I would lift the tee shirt out of the sink and let the water run down the front of my jeans and soak them then Put the tee shirt and outer shirt back on and slosh out to the bike get on and ride away. It was nirvana for about 10 minutes with the jeans, a little longer with the shirt.
