Throttle twist,
Old May 21, 2017 | 08:50 PM
springermel's Avatar
springermel
Stage I
Default Throttle twist,
I have a 2016 cvo road glide, I got in a little run off yesterday with another H.D. and when I grab second gear I twisted the throttle all the way past the stop and the bike quit until I twisted the throttle back over the stop now it wants to keep slipping. Has anyone else had that problem?
Old May 22, 2017 | 12:01 AM
whocares's Avatar
whocares
Time for a new one.you probably stripped the one you have.pull the grip off and look at it,you'll probably see the damage.
Old May 22, 2017 | 11:47 AM
Buelligan666's Avatar
Buelligan666
It could be the right hand switch housing isn't pushed inward all the way. That causes the throttle side grip to only engage the teeth partially. If you're only catching the last edge of the teeth they could have stripped out, allowing the grip to spin. Try loosening the housing and pushing it and the grip as far inward as you can.
Hematite
2014-2024 Touring Models
23
Aug 6, 2018 11:09 AM
Drew91666
Dec 24, 2012 03:57 AM
Keithhu
Mar 6, 2012 05:32 PM
coliseum
Oct 23, 2010 04:58 AM
SM49
Feb 5, 2008 12:42 AM
