TPMS issue
Old Aug 29, 2017 | 08:34 PM
Tx_Rider's Avatar
Tx_Rider
Originally Posted by Gary Andersen
Mines at the dealer now for TPMS issue with red warning light and tire light coming on, blinking at first, then both on solid. Happened out of no where. 2016 CVO Limited. Tire pressure was within specs. We shall see what they come up with.
I had the exact same issue, they replaced the rear sensor and re-calibrated.
Two days later, same thing again. Usually around 70 mph but its random.
Dealer said bring it in and leave it, let mother Harley take a look.
Old Apr 3, 2019 | 08:25 AM
smoothcvo's Avatar
smoothcvo
Did you get your issue resolved? I'm having issues with my 2017 CVO SG
Old May 19, 2019 | 10:51 AM
Riding4theKing's Avatar
Riding4theKing
has anyone received a good answer on this? I have a 2017 CVO Limited that started having problems a week after installing a new rear tire, took it in and they replace the rear sensor, two days later it started doing it again. It doesn't matter how air I out in it, the low-pressure light comes on and throws a code.
Old May 19, 2019 | 11:33 AM
kojak's Avatar
kojak
My 2017 cvo limited has never had a problem with tpms. When I had tires replaced, they damaged the sensor and had it replaced.
Old Sep 15, 2019 | 07:53 AM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Well I experienced this yesterday for the first time. I have. 2017 CVO Limited. I keep my tires at 36/40, checked them before leaving home. It was 76 degrees out at 10 am. Ride at interstate speeds approximately 35 miles and get the solid RED light and the yellow tire pressure light.
Click the button on top of the right switch pack and ZERO indication on the front wheel. I’m two miles from the exit we were getting off at for breakfast and fuel and by the time we stop the indicator lights are out and it is reading the PSI again.
The bike is two years on the road now with 20k miles and the first time this has ever happened. I also just had new tires front and rear installed three weeks ago with approximately 400 riding miles on them.
Just a fluke, or should I have the dealer look at it? We rode approximately 220 miles yesterday and it did not happen again.
Old Sep 28, 2019 | 07:21 PM
YPD485's Avatar
YPD485
Does anyone here happen to know if the TPMS sensors are hermetically sealed?
I'd like to install Ride-On tire sealant and balancer in the tires but don't know if it's ok.
Ride-On said as long as the sensors Harley uses are hermetically sealed, it's fine. I tried contacting Harley HQ's, but no one knows?
Old Sep 29, 2019 | 07:53 AM
Cosmic Razorback
I thought the only thing hermetically sealed was the mayonnaise jar in Funk & Wagnalls library on the Johnny Carson show?
Sorry could not resist!
Old Oct 25, 2019 | 02:46 PM
smoothcvo's Avatar
smoothcvo
I took mine to the dealer and had them disable it ($42.50). They wanted to start checking all kinds of crap that has been checked by 4 dealers and no one can seem to figure out the cause. Screw it. Thats one of the bells and whistles that I can live without. I have to check my wife's bike anyway. Good luck to everyone else.
Old Oct 26, 2019 | 05:18 AM
PFWiz's Avatar
PFWiz
I have been running Ride On in my rear tire for last 14K miles with no issues. TPMS still works fine....
Old Oct 26, 2019 | 06:44 PM
YPD485's Avatar
YPD485
Finally an actual positive user. Thank you.
