TPMS issue
Old Aug 8, 2017 | 09:26 PM
dixonk's Avatar
dixonk
Default TPMS issue
So today I aired up the tires to 36/40. Readout on TPMS shows 37/41 but for some reason is giving me a low tire pressure warning for the front tire. Is there a way to reset the sensor?
Old Aug 9, 2017 | 04:52 PM
mazz's Avatar
mazz
i had similar problem the red light and tpms lights on happened every couple hundred miles but only when moving. Dealer replaced front sensor.
Mazz
Old Aug 9, 2017 | 06:46 PM
dixonk's Avatar
dixonk
Mazz
So I figured it out. When I added air in the tires it was over 90° in the garage. Went out this morning and what was 37 psi yesterday turned out to be 33 psi this morning with cooler garage. Put some more air in and it is good to go.
Old Aug 10, 2017 | 11:39 AM
load97's Avatar
load97
Had the same problem. Apparently the TPMS has a set PSI threshold that's kind of on the high side. I had to get up to 39-40 PSI cold before it wouldn't trip.
Old Aug 10, 2017 | 01:37 PM
dixonk's Avatar
dixonk
Ya I’m wondering if the dealer can calibrate the threshold. I really don’t need an alert when it’s 2psi lower.
Old Aug 15, 2017 | 06:25 AM
load97's Avatar
load97
Agreed.
Old Aug 15, 2017 | 04:13 PM
D W K's Avatar
D W K
Same issues on my new 17. Never could get it to reset when hot but after it cooled down I added air and got it reset.
Old Aug 17, 2017 | 05:54 PM
Punjabi Rider's Avatar
Punjabi Rider
Moco recommends to check at 68 degrees temp and it's very rare when my garage is at 68 degrees in the summer and raise 1 psi for each additional 10 degrees so I keep mine at 38 and 43 for now.
Old Aug 17, 2017 | 07:33 PM
dixonk's Avatar
dixonk
So basically don’t check your tires from June to September...
Old Aug 28, 2017 | 02:22 PM
Gary Andersen's Avatar
Gary Andersen
Stage I
Default Tpms
Mines at the dealer now for TPMS issue with red warning light and tire light coming on, blinking at first, then both on solid. Happened out of no where. 2016 CVO Limited. Tire pressure was within specs. We shall see what they come up with.
