110 lifter
Old Aug 24, 2017 | 07:19 AM
hdman6's Avatar
hdman6
Question 110 lifter
So I am getting a new to me 2012 CVO ultra (blue) from a dealer on tuesday with 8k on it. I see the 110 has lifter issue that take out the engine when they go. I am getting the ESP for 4 yrs as well from HD. So should i replace the lifters anyway and/or did harley address the problem with a change. If I use a better one other than harley im sure it would void the ESP if it happens. just thinking ahead and also the bike is all stock as of now. thanks Jeff
Old Aug 24, 2017 | 08:04 AM
bigskyroadglide's Avatar
bigskyroadglide
Op
understand how ESP works, if you experience a failure with a mechanical item in your engine, ESP will repair the damage. what they will not do is repair it as you may want, also they will not clean anything. so say you experience a lifter failure on your 110 and metal goes throughout you engine taking out the oil pump, cams, and various other items. perhaps it even cracks the lifter bore.
ESP will replace the half of the engine case that is cracked, the cams, oil pump and lifters along with all gaskets damaged during teardown , and any bearings that show damage upon inspection.
they have ZERO obligation to repair anything else. nor will they clean the oil pan, flush oil passages etc. you get the drift i hope.
so upon start up, if you have ANY metal anywhere in the engine or if any part were within service limits, like cam plate, cam chains etc, they are re used and the metail that was not cleaned out will circulate inside you freshly repaired engine under the theory that the oil filter is designed to catch this debris.
so now you have you 110 back after 4 to 6 weeks, irs got old and new parts inside and you off riding again until it happens again. got it?
if it happens under ESP, they cover again, if yoy have not modified, if it happens outside ESP, its your nickel.
so, should you replaced your lifters, your call. if the dealer does its HD lifters, if someone else does you get a better product.
your call. my opinion is biased.
Old Aug 24, 2017 | 10:20 AM
r0de_runr's Avatar
r0de_runr
Replace the lifters. Have your selling dealer do it and include it in the price at delivery. Try to have them install the best HD lifter or perhaps S&S.
Old Aug 24, 2017 | 11:29 AM
todd-67's Avatar
todd-67
The lifters while crappy are only part of the problem. The valve springs are too stiff and help prematurely wear out the lifters causing the failure.
Old Aug 24, 2017 | 09:06 PM
r0de_runr's Avatar
r0de_runr
This is true, however what can one do?
I thought I was preventing more problems by having my heads done with AV&V springs, with new guides. At 23,500 miles. But...at 38,000 I had a spring break and ended up on a tow truck anyway.
Old Aug 25, 2017 | 03:39 PM
ssls6's Avatar
ssls6
I know what I did....I keeping my springs and plan on changing out the lifters routinely. Johnson Hylifts are about $150 a set and with new gaskets maybe $200 total. I learned to do the work myself so it’s wouldn’t be too painful cost wise or mysterous.
The first time I did cam bearings and went with adjustable pushrods to make subsequent lifter changes a bit quicker.
sixshooter
2014-2024 Touring Models
16
Mar 19, 2017 05:29 PM
BlackPearl#1
Jun 19, 2016 10:19 PM
HardyHarHarley
Exhaust System Topics
Sep 3, 2010 09:00 AM
t059736
Jun 11, 2010 09:47 AM
DiegoKing
Mar 24, 2008 10:19 PM
