Wireless Headset Issue
Old Jan 22, 2018 | 07:43 AM
robbie52's Avatar
robbie52
Default Wireless Headset Issue
Overall, I like the new wireless headsets when using the CB and/or Radio. However, if I turn on the intercom, the wind noise will activate intercom and you lose radio and/or CB. Adjusting the VOX sensitivity has no effect on wind noise. There are also configuration adjustments for headsets in menu, but the manual states that these have no impact when headsets are used with boom system. Anyone else having this issue and have a fix.
Old Jan 22, 2018 | 08:17 AM
smitty901's Avatar
smitty901
Are you using SENA head sets if so make sure you do not have it set you allow out side noise to be heard.
As for the mic work on VOX settings and place meant.
If you have HD version of the headset you can adjust them in the boom if you have SENA version you need to use the management software.
Old Jan 22, 2018 | 11:41 AM
robbie52's Avatar
robbie52
I am using the HD version and still get wind noise with the VOX setting at its lowest.
Old Jan 22, 2018 | 11:53 AM
smitty901's Avatar
smitty901
Look at you setting list what option you have chosen. Wife nor I get any wind noise with the WHIM and Sena head sets. With the old wired ones we did.
Old Jan 22, 2018 | 06:30 PM
robbie52's Avatar
robbie52
What settings are you talking about. The only setting I am aware of within Boom is the Vox sensitivity.
Old Jan 22, 2018 | 06:42 PM
smitty901's Avatar
smitty901
No there is a long list of option on your head set. Do it the easy way.
Download the HD device manager. Install it on your computer.
Open it plug your head set into usb slot with the cable that came with it for charging.
Click next if it needs updating do that first . Then look at all your options. If you have questions about any of the setting just ask.
Device manager software near the end of the page.
https://www.harley-davidson.com/us/e...-download.html
You may want to watch this SENA video your HD software works the same
https://www.sena.com/software/#device-manager
Old Jan 23, 2018 | 03:16 PM
Coastal CVO's Avatar
Coastal CVO
Go to the App Store or Play Store, search for the Sena App, it will help you with your headset settings and such, sync it with bluetooth (Phone to headset)
Old Jan 23, 2018 | 04:43 PM
robbie52's Avatar
robbie52
smitty901
Thanks for your help in trying to resolve this issue. I did download and upgraded head sets to latest version of software. Still did not see a setting that would change VOX setting for intercom within head set. All setting are currently on default settings.
Are all of your settings on the default settings?
Old Jan 23, 2018 | 07:35 PM
smitty901's Avatar
smitty901
Did you watch that video link I gave you. It show the option the default are no the best for most.
I will make a list of suggestions to try.
Old Jan 25, 2018 | 11:32 AM
robbie52's Avatar
robbie52
I watched the link, still cannot figure out what options I can change that might affect intercom. May also try the option mic on the wifes headset.
