Front suspension 15 SG CVO replacement
Old Feb 14, 2020 | 08:40 AM
Iowa cajun's Avatar
Iowa cajun
Default Front suspension 15 SG CVO replacement
I changed my rear suspension to Ohlins last year and now want to upgrade the fronts to Ohlins. I have read a lot of posts on replacement and will have a mechanic friend help me replace them. I'm not an aggressive rider and more of a set it and forget it kind of guy so i don't think adjustable fronts is the right choice. My question is did you see a huge improvement in the handling or should i just put HD fronts back in it? Who in your opinion is the best to buy the fronts from?
Old Feb 14, 2020 | 03:24 PM
DoubleD8's Avatar
DoubleD8
I highly recommend Ohlins. You will see a big difference in the way the bike rides and handles. You said you upgraded the rear already did you go with 12" or 13"? If you went with 13" on the rear I would recommend standard height on the front, not lowered.
I like Cycle Solutions. They have great customer service and good prices.
Old Feb 18, 2020 | 08:53 AM
Iowa cajun's Avatar
Iowa cajun
DoubleD8, Sorry for the delay in my response. thanks for the reply. i have 13" on the rear and figured on going with standard height.I was told by someone that before you buy them they can pre set them to your riding. Is that true?
Old Feb 18, 2020 | 04:30 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
OP you definately want aftermarket. I put Pro-Action rear shocks on a 2016 Limited and wow did it make the front end feel inferior. I traded it before I could make that change to a 2017 CVO Limited. In 2017 HD made some advancements in the front and it is not bad. But still not as good as what you will get from Ohlins, Pro-Action or Legends.
Good luck
Old Feb 19, 2020 | 08:46 AM
DoubleD8's Avatar
DoubleD8
Yes they are pre set. You may need more preload when 2 up but otherwise they shouldn't have to be adjusted.
Old Feb 25, 2020 | 04:28 PM
Iowa cajun's Avatar
Iowa cajun
DoubleD8, Did you get adjustable fronts or the non adjustables from Ohlins?
PistolPete83
Screamin Eagle CVO Models
14
May 22, 2020 10:47 PM
Superior Delight
2014-2024 Touring Models
Apr 2, 2017 08:22 PM
Blake USMC Vet
11
Apr 29, 2015 08:44 PM
crazzy76
Aug 15, 2012 09:26 PM
Older Guy
15
Jan 9, 2011 03:33 PM
