Electrical system lamp (security system) on steady while riding?
Old Oct 22, 2020 | 03:52 PM
jc15025's Avatar
jc15025
Veteran: Coast Guard
Default Electrical system lamp (security system) on steady while riding?
What does it mean when Electrical system lamp (security system) on speed gauge will light on steady after a while, while riding?
Thank you.
Old Oct 24, 2020 | 01:48 PM
Hawg Runner's Avatar
Hawg Runner
Try replacing the battery in your fob.
Old Oct 24, 2020 | 09:25 PM
jc15025's Avatar
jc15025
Thank you. Ya, Rode yesterday and used the other fob and never got the light! Came home and did a fault check, had a BCM and SPDO fault. Cleared and will see what happens.
Old Oct 25, 2020 | 01:34 AM
Baja4us's Avatar
Baja4us
It could also be a stuck or defective clutch safety switch. Try starting your bike in gear with the clutch lever pulled in. If it starts as normal you can disregard my suggestion. If it won’t start, check to see if the little button/switch located behind your clutch lever is stuck.
Old Oct 25, 2020 | 04:59 AM
jc15025's Avatar
jc15025
The Clutch safety switch is good. Thank you.
Old Oct 29, 2020 | 04:43 AM
kojak's Avatar
kojak
Usually the security light will stay on if the fob batteries start going bad. I would replace both. It can also come on for any number of electrical issues from a bad bulb in a turn signal to a short somewhere. Since it went away with the other fob, sounds like it’s your fob battery.
Old Oct 29, 2020 | 07:11 AM
jc15025's Avatar
jc15025
Thank you, I change the battery in the affected fob. Weather changed, unable to take it out and check.
Old Nov 7, 2020 | 06:46 PM
jc15025's Avatar
jc15025
Did over a 180 miles today and no light indicator.
Old Nov 8, 2020 | 06:42 AM
jc15025's Avatar
jc15025
After doing a 180 mile ride, I'm still getting a BCM code b2137, P/N 69994-128 ??
Old Nov 9, 2020 | 05:17 AM
WRE4U's Avatar
WRE4U
new headlight?
