You may have to try it a couple of times to get it to go into the service function. Sometimes I get it on the first try, other times it takes me 2 or 3 times to gt the timing correct. If you miss the first time shut off and wait a few minutes before trying again. And you have to move through the screens fairly quickly otherwise it will cycle back to the normal function.
Should be the same for all BB GTS Units2019 FLHTCUTG BOOM BOX GTS MAINT RESET
Step 2: Turn Ing to Accessory on with FOB Present.
Step 3: Once the warning display comes on touch & hold the ON/OFF button on the screen.
Step 4: When Maintenance Mode screen finally displays, take your finger off the ON/OFF button.
Step 5: Now you can scroll down to and select the reset option.
NOTE: Do not mess around with the other settings.
Shut Ing off when done to go back to normal GTS functions.
