2021 MY Calibrations
Old Jul 20, 2021 | 10:35 AM
Yardstick's Avatar
Yardstick
Default 2021 MY Calibrations
Just for your information.........there are calibrations for stage one on the CVOs. This, of course, is used when changing mufflers and a/c. Being as these bikes more or less have the a/c, if you change to mufflers, you can update the calibration and not engage EITMS so much. I ran my bike with fullsac baffles (only change) and at every stop the EITMS kicks in. Now, not so much.
I cant believe how lean they are making the calibration. Before the calibrations would be at an A/F ratio on the high end of the MAP scale and RPM of 12 or richer. Now they are set at 14.5. Not so sure that is best power or safe for the engine. My understanding is 13-13.5 is best for power. Oh well, once warranty is up, Powervision here we come.
Old Jul 20, 2021 | 10:49 AM
Yardstick's Avatar
Yardstick
Here is another thought to consider..........Harley say when you do a stage 1 that you must recalibrate the eco. Failure to do so could result in engine damage. Given the a/f listed above it could burn the exhaust valves. If that happens and the download wasn’t done I bet they disapprove the warranty claim.
Old Jul 22, 2021 | 12:46 AM
steveg56's Avatar
steveg56
Do you know if this new map is for California as well?
Old Jul 22, 2021 | 07:41 AM
rigidthumper's Avatar
rigidthumper
A little clarification is in order- While the AFR table shows 14.4/14.5 everywhere, that only applies to the low load/cruising/idle area. This keeps EPA/CARB happy. Once you're into the higher loads/RPMs, the "Lambda Performance Enrichment Table" controls the AFR requested. This is a screen shot of the table with notes- you can see it's time based, so the longer you are under load, the richer it becomes. 0 seconds into hi load throttle request, it asks for 12.77, at 22 seconds it drops to 12.26, 24 seconds and beyond 11.74.
Old Jul 22, 2021 | 03:53 PM
b0fh's Avatar
b0fh
so we all live in PE land with the street tuner then ? interesting.
can you still control when PE kicks in (TPS or MAP trigger) ?
Old Jul 22, 2021 | 08:55 PM
rigidthumper
Not in the SE software.
Old Jul 23, 2021 | 09:27 AM
Harrybeerbelly's Avatar
Harrybeerbelly
So I asked two separate HD dealers if I needed to re tune or calibrate after installing Rinehart DBX slipons. Both said nothing was necessary.
From what I read above is it possible both dealers are wrong.
Old Jul 23, 2021 | 01:21 PM
b0fh's Avatar
b0fh
well thats not promising then... on older calibrations PE would just kick in at higher RPMs like 4000-ish and WOT. they could have changed that of course but it appears that there is no way to know.
Copey
Jun 11, 2013 07:57 PM
jorswift
Exhaust System Topics
May 8, 2008 03:49 PM
OAKXTREE
Jun 27, 2007 08:49 PM
rodeo13
Apr 29, 2006 02:54 PM
traveler
Jul 27, 2005 04:56 AM
