Accessory Mode Help
Old Apr 5, 2024 | 05:00 PM
RiggerWings's Avatar
RiggerWings
Default Accessory Mode Help
I'm sure there's an easy solution to this, so hopefully one of you can make me feel like an idiot.
On the 2023.5 and up CVOs, how do you leave it in accessory mode when you turn the engine off?
To use acc mode before you start it, you simply hold the toggle button down. But, once the bike is started and you want to turn it off, your only option is to hit the kill switch which also kills the acc power.
Is there a way to keep power to the stereo after you shut down the engine?
On the earlier models, you would simply rotate the key/handlebar lock mechanism to the acc position. This isn't an option on the newer models.
Old Apr 5, 2024 | 05:30 PM
mjwebb's Avatar
mjwebb
your Owners Manual makes no mention of that?
Old Apr 5, 2024 | 07:13 PM
RiggerWings
Not that I could find while skimming for it.
Old Apr 5, 2024 | 08:51 PM
mjwebb's Avatar
mjwebb
I "skimmed" for it and found it easily in an OM
Accessory Mode
See Operation → Left Hand Control Switches → Left Hand Control Module (LHCM)
. With the key fob present, press and hold the trip switch. The instruments and accessory circuit are powered. The headlamp and turn signal lamps remain off. While in accessory mode, the IFCU displays the fuel gauge and odometer functions. The headlamp can be activated by pressing the headlamp flash to pass switch.
To turn the motorcycle back off, press and hold the trip switch.
Do not leave the motorcycle in accessory mode for an extended time. This can discharge the battery. If the vehicle is left in accessory mode for 2 hours, the motorcycle automatically shuts off to prevent complete battery discharge. To resume accessory mode, press and hold the trip switch again.
Old Apr 5, 2024 | 08:56 PM
Roadie13's Avatar
Roadie13
I had the same question when I got mine, sat down to go through the manual, got distracted and forgot about it. The times I've wanted it to stay on but not be in "run" I just hit the accessory button immediately after the kill switch and the screen comes right back, it doesn't have to reboot or anything just pops right back up. It works for me every time and maybe that's the only way to do it, but it seems more like a hack than the intended way to do it. Hopefully I think to look again the next time I have the manual out.
Old Apr 5, 2024 | 09:23 PM
30glock's Avatar
30glock
On the 2023.5 and up CVOs, how do you leave it in accessory mode when you turn the engine off?.
When you come to a stop, leave it in gear and put the Kickstand down, bike will shut off and music keeps playing..
Old Apr 6, 2024 | 06:58 AM
FLSTFI Dave's Avatar
FLSTFI Dave
This is only way I have found to keep accessory mode active when shutting off engine. Works great for quick gas stops so I do not have to wait for bike to reboot.
Old Apr 6, 2024 | 09:35 AM
RiggerWings
Accessory Mode
This is the part I knew about. My question was about once you shut the engine off. I was hoping to not turn off the stereo and have to turn it back on. That part isn’t explained in the OM.
Old Apr 6, 2024 | 09:36 AM
RiggerWings
I figured this out as well, but then it’s not in ACC mode, the headlight remains on in this case.
Old Apr 6, 2024 | 09:37 AM
RiggerWings
I’ll give it a shot. I did this once and it was like initially starting the bike. It had to reboot. Maybe I wasnt quick enough.
