headlight on 08 Springer
Old Oct 9, 2007 | 08:06 AM
SFTail06's Avatar
SFTail06
Default headlight on 08 Springer
My headlight relaly shakes up and down when the bike is running. I checked all the bolts and they are tight. The entire assy is rubber mounted. Is this normal for the movement?
Thanks
Old Oct 9, 2007 | 09:07 AM
Guilty's Avatar
Guilty
Default RE: headlight on 08 Springer
That is part of the character of the CVO Springer...dancing headlight.
Old Oct 9, 2007 | 10:30 AM
Deuce Bigelow's Avatar
Deuce Bigelow
the headlight on my '07 Springer doesn't bounce at all, but the one on my '06 Deuce did...........[:'(]
Old Oct 9, 2007 | 11:08 PM
detonator's Avatar
detonator
ORIGINAL: Deuce Bigelow
Mine bounces and if I turn the high bright on, the road dissapears because the light shines straightup! CALLING BATMAN.
I tryed to adjust it but it wouldnt adjust. The low bright how ever takes the high brights place every F*ckin person on the road high brights me @ night blinding me. The low bright is set high because I can see a far way down the road with low beam.
Old Oct 10, 2007 | 11:56 AM
hogsnhogsnhogs's Avatar
hogsnhogsnhogs
6th Gear
Same problem on my 08 springer
Real pain to adjust height since you have to loosen up mount,guess at setting, ride down road and most likely readjust
They all seem to be that way though, my buddy's 2003 has the rubber mount
I think it's more noticiable now since the headlight output is brighter than before
calxen61
Mar 14, 2013 08:23 AM
09CVOspringerman
Electrical/Lighting/Alarm
Feb 27, 2010 09:20 PM
JRK5892
Aug 13, 2008 04:22 PM
skullhead
May 28, 2008 02:01 PM
wally1997
May 16, 2007 08:00 PM
